Condition — the value has changed in Global Triggers
Hello
please check
Condition — the value has changed in Global Triggers - not works
I used specific variables.
Hi,
Here’s why your trigger doesn’t fire:
  • “Value has changed” is only true for a split second. “Trigger conditions are true for X seconds” waits for the conditions to stay true longer than that, so the trigger never fires.
  • Your reset condition is “Button_Limit is equal to 1”, so the first press after startup only resets the trigger instead of firing it.
Please try this setup:
  • Trigger condition: 'Button_Limit' is equal to 1
  • Trigger conditions are true for: 0
  • Reset condition: 'Button_Limit' is equal to 0
This fires once each time you press the button.
If your action is “Set value on trigger status”, change it to “Toggle value On/Off”. “Set value on trigger status” sets the value back to 0 when you release the button, so it won’t stay on.
Let me know if it works.
Thanks, You’ve made my job easier.
