Hi,
Trying to connect RealDash via the OBDLink MX Wifi unit. I have use this OBD module flawlessly with other software (OBDLink on Android). In this case, gauge refresh rate is quite fast.
However cannot get RealDash to work - constantly getting messages in the lower right corner (refer attached movie/image) - Connecting… / i Checking PID support / OBD2 Stopped Connecting… This happens continuously. Only once managed to get a connection for a few seconds. The above is the situation on both my Android 10 phone and an Android 9 Car Radio/head unit. I can confirm that the IP address and Port values are correct.
I have also tried connection with an older OBDLink Bluetooth OBD module and managed to connect. In this case, dial reaction time was very slow with 1-2 seconds delay between updates.
Could you assist to manage to connect via Wifi?
Thanks & regards
RIchard
