Hello everyone
I want to connect to RD via RD CAN/Serial
Hardware:
Rock5B (8GB RAM) with 256GB NVMe Samsung 870 EVO
Teensy 3.5 for signal processing (not yet connected)
Currently only a display is connected to HDMI 2, 1x mouse and 1x keyboard (USB).
The OS is Armbian 23.11.1, kernel 5.10.110 with xfce.
When selecting the serial connection, RD shows me 2 entries to choose from, but I cannot assign them (what is that, - which device does it mean?):
/dev/ttyFIQ0
/dev/ttyS6
So it’s not clear to me which of the two I have to use in RD…
- Is this name perhaps referring to the individual Rock5B GPIOs or UART devices?
Another question:
What is the best way to prepare analog and digital signals (such as indicators, lighting, temperatures, pressure etc) for RealDash to process?
- Both in Teensy 3.5 with only one serial connection to RD, output via RXTX to the Rock5B’s GPIO?
or
- only analog via the Teensy, and digital directly via the GPIO PIN’s from the Rock5B with a second serial Connection for RealDash ?
I would be very happy about your tips!
You question is very broad and difficult to answer.
Linux shows the USB names like that. There is no way of knowing to which device each name refers to. One way is to detach the device while on that screen and see what name disappears.
As for your another question, absolutely best option is to not use any custom hardware at all, just use one of the supported CAN adapters to directly connect to your vehicle CAN bus.
Hello realdashdev,
Thank you very much for your quick answer!
Unfortunately the vehicle doesn’t have a CAN bus - only OBD2 - and even then a lot of interesting data isn’t displayed to me at all…
That’s why custom hardware…
At the moment the Signal setup looks like this (not yet connected):
Analog / Digital Signal => Teensy 3.5 In => Teensy 3.5 RXTX Out (UART) => Rock5b GPIO In => RealDash
- The question is whether the signals should all be (pre)processed in the Teensy (and RD only has to use one serial connection for this)?
or
- whether you just put the digital signals directly on the Rock5B GPIO (the analog signals remained on the Teensy) and create a second serial connection in RD?
/dev/ttyFIQ0 and /dev/ttyS6:
When I display the hardware information from the Rock 5B with ls /dev, there are around 67 tty entries - these can’t just be USB devices (which change with every start)…
/dev/ttyFIQ0 and /dev/ttyS6 are the last two in the list.
What does the connection name that RealDash offers in the serial settings refer to?
GPIOs or any overlays are not yet activated in the Rock5b.
Where does the name that RealDash uses there come from?
There must be a reason why RD offers two different names for the serial connection…
Is this a name that Linux assigns per hard drive/volume?
Could it be that the two tty entries are related to the two volumes of the (only) installed SSD?
lshw-short shows me 2 volumes even though only one SSD is physically installed…?
here is my Hardwareinfo:
type or paste code here
ls /dev/tty
ashmem hidraw0 loop-control snd tty28 tty52 vcs4
autofs hidraw1 mali0 stderr tty29 tty53 vcs5
block hidraw2 mapper stdin tty3 tty54 vcs6
btrfs-control hugepages mem stdout tty30 tty55 vcs7
bus hwrng mpp_service sw_sync tty31 tty56 vcsa
cec0 i2c-0 mqueue tty tty32 tty57 vcsa1
cec1 i2c-1 mtd0 tty0 tty33 tty58 vcsa2
char i2c-10 mtd0ro tty1 tty34 tty59 vcsa3
console i2c-11 mtdblock0 tty10 tty35 tty6 vcsa4
cpu_dma_latency i2c-4 net tty11 tty36 tty60 vcsa5
crypto i2c-6 null tty12 tty37 tty61 vcsa6
cuse i2c-7 nvme0 tty13 tty38 tty62 vcsa7
disk i2c-9 nvme0n1 tty14 tty39 tty63 vcsu
dma_heap iio:device0 nvme0n1p1 tty15 tty4 tty7 vcsu1
dri initctl nvme0n1p2 tty16 tty40 tty8 vcsu2
drm_dp_aux0 input port tty17 tty41 tty9 vcsu3
fb0 kmsg ppp tty18 tty42 ttyFIQ0 vcsu4
fd kvm ptmx tty19 tty43 ttyS6 vcsu5
full log pts tty2 tty44 ubi_ctrl vcsu6
fuse loop0 ram0 tty20 tty45 uhid vcsu7
gpiochip0 loop1 random tty21 tty46 uinput vhci
gpiochip1 loop2 rfkill tty22 tty47 urandom video0
gpiochip2 loop3 rga tty23 tty48 v4l zero
gpiochip3 loop4 rkspi-dev2 tty24 tty49 vcs zram0
gpiochip4 loop5 rtc tty25 tty5 vcs1 zram1
gpiochip5 loop6 rtc0 tty26 tty50 vcs2
hdmirx_hdcp loop7 shm tty27 tty51 vcs3
lshw -short:
H/W path Device Class Description
system Radxa ROCK 5B
/0 bus Motherboard
/0/1 processor cpu
/0/1/0 memory 32KiB L1 Cache
/0/2 processor cpu
/0/2/0 memory 32KiB L1 Cache
/0/3 processor cpu
/0/3/0 memory 32KiB L1 Cache
/0/4 processor cpu
/0/4/0 memory 32KiB L1 Cache
/0/5 processor cpu
/0/5/0 memory 64KiB L1 Cache
/0/6 processor cpu
/0/6/0 memory 64KiB L1 Cache
/0/7 processor cpu
/0/7/0 memory 64KiB L1 Cache
/0/8 processor cpu
/0/8/0 memory 64KiB L1 Cache
/0/9 processor cpu-map
/0/a processor idle-states
/0/b processor l2-cache-b0
/0/c processor l2-cache-b1
/0/d processor l2-cache-b2
/0/e processor l2-cache-b3
/0/f processor l2-cache-l0
/0/10 processor l2-cache-l1
/0/11 processor l2-cache-l2
/0/12 processor l2-cache-l3
/0/13 processor l3-cache
/0/14 memory 7688MiB System memory
/0/100 bridge RK3588
/0/100/0 /dev/nvme0 storage Samsung SSD 970 EVO Plus 250GB
/0/100/0/1 /dev/nvme0n1 disk 250GB NVMe disk
/0/100/0/1/1 /dev/nvme0n1p1 volume 256MiB EXT4 volume
/0/100/0/1/2 /dev/nvme0n1p2 volume 230GiB EXT4 volume
/0/101 bridge RK3588
/0/101/0 wlan0 network Realtek Semiconductor Co., Ltd.
/0/0 bridge RK3588
/0/0/0 enP4p65s0 network RTL8125 2.5GbE Controller
/1 usb1 bus EHCI Host Controller
/1/1 bus USB 2.0 Hub
/1/1/1 input5 input USB Keyboard Consumer Control
/1/1/2 input8 input PixArt USB Optical Mouse
/1/1/3 communication Bluetooth Radio
/2 usb2 bus EHCI Host Controller
/3 usb3 bus Generic Platform OHCI controller
/4 usb4 bus Generic Platform OHCI controller
/5 usb5 bus xHCI Host Controller
/6 usb6 bus xHCI Host Controller
/7 usb7 bus xHCI Host Controller
/8 usb8 bus xHCI Host Controller
/9 mmc0 bus MMC Host
/a mmc1 bus MMC Host
/b mmc2 bus MMC Host
/c card0 multimedia rockchiphdmi0
/d card1 multimedia rockchiphdmi1
/e card2 multimedia rockchipdp0
/f card3 multimedia rockchipes8316
/10 card4 multimedia rockchiphdmiin
/11 /dev/fb0 display rockchipdrmfb
/12 input0 input rk805 pwrkey
/13 input1 input rockchip-hdmi0 rockchip-hdmi0
/14 input2 input rockchip-hdmi1 rockchip-hdmi1
/15 input3 input rockchip,dp0 rockchip,dp0
/16 input4 input rk-headset
/17 input9 input BRLTTY 6.5 Linux Screen Driver Keyb
/18 wlP2p33s0 network Wireless interface
root@rock-5b:~# lsusb
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 005: ID 0bda:b85c Realtek Semiconductor Corp. Bluetooth Radio
Bus 001 Device 004: ID 093a:2510 Pixart Imaging, Inc. Optical Mouse
Bus 001 Device 003: ID 04d9:1603 Holtek Semiconductor, Inc. Keyboard
Bus 001 Device 002: ID 1a40:0101 Terminus Technology Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
I do not know answers to your Linux specific questions, sorry
AS for your custom hardware, use only one connection from your device to RealDash and do all the numbers crunching on your Teensy/Rock5b. At the end of the day, RealDash is designed to be a display software. While it can do some conversions to values, it is best to send the data that is already in proper format.
