I made you a video once. The microcontroller keeps sending demo data. Maybe this will help.
https://www.youtube.com/watch?v=PucejzoptNU
Greetings René
Greetings René
Try removing the connection in the garage, then re-creating the connections and reconnecting the description file.
I had this a couple of times when switching from version to version.
It would also be nice to see your description file and an example of Firmware uploaded to the controller … As I understand it, in this case the controller itself calculates the values?
Hi I’m getting an error “link ecu not supported” after update. I’m running version 1.7.2 ecu is link g4+ connecting via serial.
As the USB library was changed you may need to set up the connection again in Garage. Sorry for the inconvenience.
I confirm. After 172. I re-established the connection in the garage. Everything works!
I have tried to delete and reconnect in garage but unsuccessful. I will try to reinstall the app completely.
