Hello everyone, I need help.
We need to make sure that all the digital outputs of 53 pins are used on the arduino mega, only 12 work, the xml file is also redone, but there is no result, please help.
type or paste code here
 *  Name        : RealDash_CAN.ino
 *  Part of     : RealDash
 *  Author      : Jani Immonen
 *  Created     : 15.10.2017
 * Arduino example sketch of how to use RealDash CAN protocol.
 * This example code is free for any use.
 * www.realdash.net
// Arduino digital and analog pins
unsigned int digitalPins = 0;
int analogPins[7] = {0};
void setup()
  // init serial
  Serial.begin(115200);
  delay(100);
void loop()
  ReadDigitalStatuses();
  ReadAnalogStatuses();
  SendCANFramesToSerial();
  // just some dummy values for simulated engine parameters
  if (rpm++ > 10000)
    rpm = 500;
  if (kpa++ > 2500)
    kpa = 10;
  if (tps++ > 1000)
    tps = 0;
  if (clt++ > 230)
    // all values in frame are handled as unsigned values. To have negative values,
    // offset actual value and write corresponding conversion to xml file imported to RealDash
    clt = 0;
  if (textCounter++ > 4000)
    textCounter = 0;
  delay(5);
void ReadDigitalStatuses()
  // read status of digital pins (1-53)
  digitalPins = 0;
  int bitposition = 0;
  for (int i=1; i<14; i++)
    if (digitalRead(i) == HIGH) digitalPins |= (1 << bitposition);
    bitposition++;
void ReadAnalogStatuses()
  // read analog pins (0-7)
  for (int i=0; i<7; i++)
    analogPins[i] = analogRead(i);
void SendCANFramesToSerial()
  byte buf[8];
  // build 1st CAN frame, RPM, MAP, CLT, TPS (just example data)
  memcpy(buf, &rpm, 2);
  memcpy(buf + 2, &kpa, 2);
  memcpy(buf + 4, &clt, 2);
  memcpy(buf + 6, &tps, 2);
  SendCANFrameToSerial(3200, buf);
  // build 2nd CAN frame, Arduino digital pins and 2 analog values
  memcpy(buf, &digitalPins, 2);
  memcpy(buf + 2, &analogPins[0], 2);
  memcpy(buf + 4, &analogPins[1], 2);
  memcpy(buf + 6, &analogPins[2], 2);
  // write 2nd CAN frame to serial
  SendCANFrameToSerial(3201, buf);
  // build 3rd CAN frame, rest of Arduino analog values
  memcpy(buf, &analogPins[3], 2);
  memcpy(buf + 2, &analogPins[4], 2);
  memcpy(buf + 4, &analogPins[5], 2);
  memcpy(buf + 6, &analogPins[6], 2);
  // write 3rd CAN frame to serial
  SendCANFrameToSerial(3202, buf);
  // build 4th frame, this is a text extension frame
  // only send once at 1000 loops
  if (textCounter == 0)
    SendTextExtensionFrameToSerial(3203, "Hello RealDash, this is Arduino sending some text data");
  else if (textCounter == 1000)
    SendTextExtensionFrameToSerial(3203, "Tomorrow's forecast: Lots of sun and 30 degrees centigate");
  else if (textCounter == 2000)
    SendTextExtensionFrameToSerial(3203, "Now Playing: Insert your favorite song info here");
  else if (textCounter == 3000)
    SendTextExtensionFrameToSerial(3203, "Message from Arduino: All systems running at nominal efficiency");
  Serial.write(serialBlockTag, 4);
  // CAN frame payload
  Serial.write(frameData, 8);
void SendTextExtensionFrameToSerial(unsigned long canFrameId, const char* text)
  if (text)
    const byte textExtensionBlockTag[4] = { 0x55, 0x33, 0x22, 0x11 };
    Serial.write(textExtensionBlockTag, 4);
    // text payload
    Serial.write(text, strlen(text) + 1);
