Correct targetid
Could you help me? I’m making a code for average consumption, instantaneous consumption and autonomy with a direct signal from the injector nozzle because my car is a 97 Palio and I was in doubt if these are the correct target IDs 221, 222, 223 and 224?
You can double check the target ID:s here:
RealDash | Manuals | Target Identifiers
Good morning, let me clear up a doubt. I’m using the speed via GPS, but it only works if I close and open the app. That’s where my doubt comes in. I need to specify the GPS speed in the XML so I don’t have to close and open the app for it to work. In my XML, I didn’t specify the speed, so it works via GPS, but I’m having this problem of closing and opening the app for it to work.
