Hi all!
I was emailing tech support a bit (thanks again Jani for the assistance!) and figured I’d pick the brain of some others as well.
I have a ProEFI128, which communicates via canbus. The canbus addresses of each individual point are known and published. Jani suggested I purchase a USB to can adapter from seeedstudio (super cheap, comes with a 120 ohm resistor too) which should work with the app on an Amazon Fire tablet. Now the xml needs to be written for the canbus addresses.
Does anyone have a working xml for any other standalone ECU so I could see how its written, and compare it to that ECU’s canbus published addresses? Writing and testing the ProEFI’s xml after that should be easy.
Thank you!
