Wanted to share with everyone that I’m trying to finish up some testing of a CANable mini PCI-e card that also has the capability of using an external GPS and compass module.
could this be plugged into a PCI-e to USB-C adapter?
I would think that would work, as long as the USB pins are exposed properly n the mini pci-e slot. I would wonder why not just use a can device over the usb c port instead of doing a double conversion.
mainly just because this can do both, if the conversion works.
You’re talking about doing both the GPS and Canbus?
