How to do at each ignition start up (dashboard startup sweep)?
Or how to bind to BODY ELECTRONICS - IGNITION ON - 167
I would like to know this to. When Realdash starts, it does a sweep, but I want it also on a certain event, like when the car is started (example: sweep when RPM data is present) even though Realdash has already started up.
I can add an action to activate startup sweep.
You mean to add it to Realdash as a function that is not present yet, or is this already a function of Realdash and I only need to set a trigger or action?
If the latter one is true, how to set this trigger/action for example: sweep when RPM data is detected/above a certain level?
Action will be on next release of RealDash.
