How to I use this?
Thanks,
Mostatfa
How to I use this?
Thanks,
Mostatfa
First, review the datalog settings in ‘Settings->Application->6th page’. Select format and values you wan’t to include into the log file.
Then you can toggle datalogging active from quick settings. Activate top menu and press lower right corner gear icon. Then tap ‘Start Datalogging’ button. Also, many of our dashboards have a quick button to toggle datalogging on/off.
I have done this just did not know where the files are.
Is there a playback mode?
Thanks,
Mostafa
Yes. In the connection settings, select the desired item
On Android, datalog files are save to Internal storage/RealDash/datalogs
Ok, Got this working, added two item to the list but can not find them on the list to view, what do I need to do?
Thanks,
Mostafa
found the issue.
Thanks.
