Data Multicast crashes
After the latest update, after adding two devices to same network and adding the same IP address and the port number, one of my devices crashes the app.
They should not have the same IP address, but on the other hand it should not crash either. Will investigate.
I did some testing and found no issues with Multicasting. However, I did find a crash from Text to Speech engine when called from multicast data.
Would you be able to verify that you do not encounter crash if ‘Speak Notifications’ option is disabled?
It seems like it was user error on my part. But I ran into problems with the music player on while using Youtube Music, the music controls like pause, previous track, next track, and just song switching to next naturally, causes a crash. Spotify seems to work fine what i’ve tested on Android 10&11. It has also weird anomaly when the multicast has been left open & and both devices are in the same network, (hotspot by the other device), bluetooth enabled, and Realdash is started again, both devices will, for some reason, asks the bluetooth to be turned on, and when checking on both devices, bluetooth is suddenly disabled.
Try disabling ‘Settings->Application->Automatic Bluetooth Enable/Disable’ option.
