Data speed problem
Data speed is an issue as the numbers are very fast IN can monitor
Fast data is an issue?
Yes, I have a problem where the indicators and icons, such as the right turn and the fog lamp indicator, are irregular and fast. What is the solution? Note that I SWAP LS3 engine ON Jaguar .
I found the problem through the monitor. I found a conflict in the bytes, as there is an id x001f5 from the PCM unit similar to the id x001f5 in TCM. Is there a solution to unmerge the id? swap ls3 gmc engine for jaguar xj
