Might be a long shot …
but maybe it is possible to include an option for EMU Master compatible log file export?
I mean they are advertising their Serial-to-Bluetooth and CAN-to-Bluetooth devices also with reference to RealDash. So who knows, maybe they’d share the specs of their log files.
Because the available formats like csv and msl can’t be imported into the EMU tuning software, therefore not used for Autotune for example.
Would boost the amount of RealDash users from Ecumaster community.
I’ve tried.
Unfortunately without any reply at all.
So I don’t expect they are willing to open their software for any kind of opend format and also not willing to share their proprietary format.
For me it’s been mainly about Autotune.
I’ll try as a workaround to use RealDash log data and to perform the Autotune with MegalogViewer HD. Then copy the modified data into Ecumaster Software.
I mean basically I can import any 16x16 VE table in MLVHD and use my own AFR target table and choose signals for actual AFR and for EGO correction. Also I can set my filters (RPM, MAP, CLT, …) with any custom channel from RealDash log. So I’ll give it a shot.
And with both ECUs the PW calculation of Alpha-N with MAP multiply is the same according documentation.
