I live in Brazil, here we use the date format DD/MM/YYYY. Without selecting European date format, I have the separator with /, but MM/DD/YYYY. If I select European format, I have DD.MM.YYYY, with dots as a separator. There would be the possibility to have options to select the separator (dot or /) and to select between MMDDYYYY or DDMMYYYY. Or add one more option between the two, they would be: MM/DD/YYYY, DD.MM.YYYY and DD/MM/YYYY. Thank you.
I will check what I can do about it.
Edit: confirmed that date and time format options will be extended on next version (1.7.5).
Now available for testing in 1.7.5 BETA3.
Thank you very much!
