Thank you very much for your answer. I found the codes on the internet and you translated them, unfortunately it did not work.
My car is ford fiesta mk8 screen. I have codes that I work on my desk. Please help me if I share.
//Vehicle Alarm + Parking Brake
opSend(0x3C3, 0x00, B11111111, handbrake, brakeApplied, 0x00, 0x00, 0x00, 0x00);
//Bytes 1/2: B11111111=Alarm
//Byte 3: B00010000=Park Brake
//ABS
opSend(0x416, 0x0E, 0x00, 0x00, 0x00, 0x00, tc, 0x00, 0x00);
//Byte 6: B00000100=Slow flashing TC, B00000010=Solid TC Light
//Byte 7: B10000000=Rapid flashing ABS, B01000000=Solid ABS
//TPMS
opSend(0x3b4, tpms, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00);
//Byte 1: 49=Shows Low Tire Pressure Menu, B00000100 shows still tire warning, B00001000 shows flashing tire warning
//Byte 2: Highlights Front R and L tires
//Byte 3: Same as above but rear
//ECU
opSend(0x421, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00);
//Byte 1: B00001000=Flashing CEL, B00000100=Solid CEL
//Charging System
opSend(0x42C, 0x00, 0x00, 0xA6, 0x00, 0x00, 0x00, 0x00, 0x00);
//Byte 2: 17=Charge Light (No Message on Screen)
//Power Steering
opSend(0x877, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00);
//Language?
opSend(0x191, 65, 17, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00);
//Byte 1: Units; 65=KM and CELSIUS
//Byte 2: 17=English, 35=German
//Outside Temp
opSend(0x3B3, 0x00, 0x00, 0x00, 0x00, 125, 0x00, 0xFF, 0x00);
//Byte 5: Outside Temp Value β 125=22Β°C
//Front Camera
opSend(0x3D8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00);
//Tractioncontrol
opSend(0x46A, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00);
//High Beam + Auto Hed
opSend(0x46B, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, fullBeam);
//Byte 8: B00110000=High Beam
// RPM
opSend(0x42F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, rpmgate, finetune);
// Speedometer INOP
opSend(0x202, 0x40, 0x00, 0x00, 0x00, distance, distance, speed, finetuner);
opSend(0x591, 0x91, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF); // Keep alive signal
opSend(0x3B2, 0x45, 0x00, 0x00, 0x8E, B00000000, 0x00, B00000000, 0x00); //Ignition
opSend(0x179, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00); //Odometer and Service
opSend(0x156, 0x00, 0x00, 0x00, 0x00, 0x23, 0x00, 0x00, 0x00); //Coolant
opSend(0x04C, 0x00, 85, 85, 0x00, 0x00, 0x00, 0x00, 0x00); //Airbag
opSend(0x213, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00); //Parking Brake (Fusion 2013)
opSend(0x3C3, 0x00, B11111111, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00); //Vehicle Alarm + Parking Brake
opSend(0x416, 0x0E, 0x00, 0x00, 0x00, 0x00, B00000000, B00000000, 0x00); //absLight
opSend(0x3b4, 0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00); //TPMS
opSend(0x421, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00); //ECU
opSend(0x42C, 0x00, 0x00, 0xA6, 0x00, 0x00, 0x00, 0x00, 0x00); //Charging System
opSend(0x877, 0x23, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00); //Power Steering
opSend(0x191, 65, 17, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00); //Language?
opSend(0x3B3, 0x00, 0x00, 0x00, 0x00, 100, 0x00, 0xFF, 0x00); //Outside Temp
opSend(0x3D8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00); //Front Camera
opSend(0x46A, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00); //Tractioncontrol
opSend(0x46B, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, B00000000); //High Beam + Auto Hed
