I see there are options to be able to pull data from websites like temperature and such. Is there anyway for you to add where a pool density altitude from your location?
What would be your use-case for that value? We do receive Atmospheric pressure on the sea level, hPa, which I believe can be used to derive other values. Not an expert on on weather data though.
We use it at the drag strip to know how the air is. this helps to know how we need to have the tune for the conditions.
What would be the calculation you need?
Calculate Density Altitude
Density altitude corrects pressure altitude for temperature deviations. For every
the actual temperature is above ISA, the density altitude increases by 120 feet.
Desity Altitude = Pressure Altitude + [120 x (Actual temp - ISA Temp)]
Desity Altitude = -307 + [120x(16.1-15.6)]
Sample:
Desity Altitude = -307 + (120x0.5) = -307+60 = -247 feet
Alright, I will try to figure this out for next releae.
