It’s just a dashboard suggestion. Could you add reinterpretations of dashboards from older vehicles like the VW Digifiz Dash and VW Beetle? This would be as premium dashboards, of course
Will add these to feature request list.
I actually have a VW Digifiz Dashboard about 90% complete will post soon if you would like it Dev
Great! Post as soon as you have it online and I will put it into test.
It’s posted,
may have some errors but should work.
All works on my sim, but I haven’t had it in a real environment as of yet.
Let me know if it works out or needs improvement / edits.
Did this dash or request moved forward?
No it have not. We are resource bound on graphics design currently.
Ok. Thanks for the quick reply.
The obvious problem with a Realdash digifiz is how to feed it with analog signals (turn signals, high beam)… if one were to replace the VW Mk2 cluster completely (way beyond my capabilities).
But just starting to play with realdash customization capabilities. Let say I keep the Mk2 cluster but use a 5" android telephone… CAN to USB…to design Digifiz style gauges…for oil PSI, oil temp, AFR, boost, Voltage, fuel psi.
I think I can use background image for label (temp) and for the reference bar on the right, then add a new indicator bar, position it vertical. But, can it be possible instead of a “solid” bar… to mimic the digifiz style bar?
