Why is it not possible to stream directly via Serial?
It’s easier to connect an Arduino to Vehicle (that does not support CAN or anything else, like older cars) and stream directly via Serial Port without usage of CAN, Bluetooth or something…. Or did I miss a Point?
Sure you can connect your Arduino via Serial to RealDash. And the data does not have to come from ‘real’ CAN source, it can be custom made in your Arduino sketch.
Our Arduino examples basically work like that, they have serial connection to RealDash and generate the data by themselves in Arduino code. They are not connected to any ‘real’ CAN device.
Hi mate - sort of in between -
I do an analogue measurement unit thats reads the inputs directly - and then pretends to be an OBD unit over bluetooth -
that way it works with Torque and Realdash to sample and relay the real quantities for vehicles that dont have an OBD port or ECU.
designed for motorbikes but works with cars if desired.
google “OBD Bridge Rae-San” if that sounds of interest.
