The problem is that when you start the instrument panel or when the connection is broken, all sensors that have a high “smoothing” value (99.94%) begin to smoothly gain their values.
This is not convenient for everyday use.
I already made this request, but Jani, refused me …
I propose a new solution.
You can make a trigger that will turn off anti-aliasing for the entire panel. Thus, the user will be able to configure for himself the time required to restore the readings and turn on SMOOTHING again for normal operation.
Please temporarily disable anti-aliasing at least for fuel level
When I refuel, I wait a very long time until the fuel level recovers.
Should there be at least some solution?
Smoothing is good when driving, but bad when you need to quickly refuel or just turn on the panel.
