Hi,
is there a way to find out, which dummy variables and/or dummy timers are used in a dashboard? I want to add some functionality to a existing dashboard, but I don’t want to interfere with already used varables. Something like a list or a config file with the IDs used in this specific dashboard?
Cheers
Not an easy way other than checking all Triggers and Actions, sorry
In some cases you could use the Debug Data View in ‘Settings->Application->Debug’ to see if certain Dummy variables have changed.
Ok thanks, this is what I had suspected…
But could you at least tell this for your own dashboards?
I’m using the “Default” and the “720RD” dashboard.
Yes, I have seen your request before, as I already explained that you just need to save your dashboard in its initial state.
Extra dummy variables could be added, but I doubt that all of them are really in use. We have created pretty complicated dashboard animations and never ran even close to consuming all dummy variables. This is a case of which is better; you optimizing your dummy variable usage, or us adding more which will add performance load and complexity. I’d prefer you first try optimizing your designs.
