Dynavin radio how autostart Realdash
Good morning. I need advice on how to run the application when starting. I know you can allow the settings to start at the start, but it doesn’t work. I have a car radio from Dynavin Model D9-3B Premium Flex and there the system (Android) in the car radio will sleep or something, so after starting the system does not start, but only wakes up. Therefore, the autostart app probably does not work. Does anyone have advice on how to do it.?
Every Android radio we have encountered allows to choose a navigation app that is launched with the device. RealDash is listed as selectable navigation app.
Excuse me, but I don’t understand how the navigation is related to the fact that when the car is started, the car stereo starts, but the realdash app does not. only the last selected radio station is playing in the foreground. I have to run it manually. I need to make the application start automatically after startup. I’m sorry, maybe I worded it wrong.
Go to Settings on the general Android screen, then go to Navigation, select RealDash Automatically, then turn it on at startup.
Thanks for the answer, but where do I find the settings. In the android settings or on the main screen. The Dynaway application from the car radio manufacturer is used as navigation on the main screen. Thanks for your patience.
On Android, go to Settings, Developer options, Startup apps. There you can choose RealDash to run at startup.
Thanks for the direction, I have the developer item there, but I can’t find the start app item. Android 11. Model: PX30_Android11
I searched but this option to run apps is not there.
Thanks a lot for the direction. I thought it wouldn’t be that easy.
