Hi
I adjusted wheel dimensions, calibrated gear ratios, and then did some pulls. I think my results are a bit too high. I saw that the cars weight is set at 1650kgs standard.
Where can i adjust the weight, and will it affect the dyno result?
Regards
Yes, vehicle weight affects the power/torque calculations. You can change the vehicle weight in:
