Eap32 fuel level to real dash
Hello guys . Pls can anyone give me a hand here. I try so hard but is so difficult
I have a smart 450 600cc 2000 model .
My last project is work with
1- elm327 ( Bluetooth)
I can see rpm , gear etc nice and good .
And
2- work with esp 32
Here I try to make connection with realdash and se only the fuel level
For esp32
At least now I can see it at realdash dashboard
I add it ,
Add-> adapters (can/lin) → realdash can ->bluetooth-> esp32
And at can description file I put mine xml.
Until now I see esp connect and at can monitor show
000000c8: e6 02 00 00 00 00 00 00
And all time the first . Numbers change all time
My problem is that I can’t see level fuel messurment .
I already find from my car fuel level sensor sender I make a good circuit to read there the data .
I think is all ok and just need find the way to see realdash the correct reading data. Can pls help me?
This is the .xml file
And this is .ino
#include <BluetoothSerial.h>
BluetoothSerial SerialBT;
// Fuel level simulation from analog pin
int fuelSensorPin = 34;
float fuelLevel = 0;
void setup() {
Serial.begin(115200);
// Για debug μέσω USB
SerialBT.begin(“ESP32-Fuel”);
// Όνομα Bluetooth συσκευής για RealDash
delay(1000);
void loop() {
int rawValue = analogRead(fuelSensorPin);
// Ανάγνωση 0-4095
float voltage = rawValue * 3.3 / 4095.0;
// Μετατροπή σε τάση
fuelLevel = voltage / 3.3 * 100.0;
// Μετατροπή σε ποσοστό
// Πακέτο CAN για RealDash
byte buf[8] = {0};
unsigned int fuelValue = (unsigned int)(fuelLevel * 100); // π.χ. 63.25% γίνεται 6325
buf[0] = fuelValue & 0xFF;
buf[1] = (fuelValue >> 8) & 0xFF;
SendCANFrameToSerialBT(200, buf); // CAN ID = 0x00C8 = 200
delay(500);
void SendCANFrameToSerialBT(unsigned long canFrameId, const byte* frameData) {
SerialBT.write(serialBlockTag, 4);
SerialBT.write((const byte*)&canFrameId, 4);
SerialBT.write(frameData, 8);
Can pls help me ?
This is an indication that analog read in your ino file is getting constantly changing values and may not be working correctly.
Try to send the raw analogRead value to the CAN frame to inspect in RealDash CAN monitor of what you are getting from the sensor.
