hi folks, I’m using a ECU that needs custom CAN template file, but I’m not 100% on making that I have all the info on the CAN stream from the ECU few examples attached, I was going to look at the other pre defined ECU’s but im not sure where the files are located, any top tips ? thanks !!
ok I may have sussed the XML file now, BUT oddly im using this adapter, which using its own software I see CAN data flying by, but I cant see it via CAN monitor on real dash, im not 100% which of the options I should be using… ?
Its probably the baud rate setting. See this page for info:
