So i usually edit on my laptop. But last night I did some editing on my desktop computer. After transferring it to my car’s Android unit, the dash appears smaller and I have to zoom in considerable to fill the screen. I was wondering if there is any way to remedy this, and return to a size closer to the original.
See this on FAQ:
http://realdash.net/forum/viewtopic.php?f=56&t=1552&sid=a50f8703269ea4e38566233e47e23c52
Is it possible to create an option in the settings that would have Realdash simply stretch the screen so that it doesn’t resize the file? I noticed if you resize the screen it does stretch the dash, but then Realdash reloads. Is there a way to simply toggle that off?
If your dash does not require autoscaling, edit your dash, select all gauges and disable ‘Scale on load’ option in Look’n Feel.
I could not find that option in “Look and Feel”.
Gauges selected, Look’n Feel->Special->Disable Aspect Correction on Load.
ahh! Thank you!!!
