Emtron xml wanted
Has anyone got a decent working Emtron XML they wouldn’t mind sharing?
Does Emtron have CAN info available? I can make you a XML if it is.
Yes I have a PDF with all the info available, do you have an email address I can send it to?
contact@realdash.net
Did you receive my email with the pdf?
That would be very useful am hoping the CAN info is correct !! :sunglasses:
I did. Was busy with 2.3.0 release. Will take a look any day now.
Sorry for the delay. Here is an Emtron CAN XML based on the documentation chapter 2.1.
RealDash-extras/RealDash-CAN/XML-files/Emtron at master · janimm/RealDash-extras (github.com)
Please let me know if it works. I will then add it to the RealDash.
Hi @m400sub I’m having the same issue (trying to establish communication between an EMtron KV8 and a TEYES CC3 Pro head unit running RealDash via a CAN-USB converter)… any chance I could get a copy of the XML-CAN info? Cheers
Yes I got it working, I’ll need to dig it out and the can stream info I used in the Emtron.
