Hi, i want use your RealDash with my EMU Black, but i have question. There is any chance that im use esp32 with BLE and can transciver to push data from can to android devices ?
That code below should works fine or im make mistake?
Yes, you can use esp32 to read CAN and pass the frames to RealDash using RealDash CAN protocol:
If you do not have anything else than passing frames in mind, there are many adapters already that do this for you. See supported CAN adapters:
https://realdash.net/manuals/supported_can_lin_analyzers.php
