How can external analog sensors be connected with a system on PC and USB connector? Arduino uno or CAN/LIN?
I am using a pressure sensor, and an Innovate Motorsports LC-2 wideband (via digital serial). I use an Arduino Mega to interface to both. Takes time, and is a pain, but rewarding when you see it work!
how did you connect to realdash CAN, OBDII or other?
I am using the USB port on the Arduino, and feeding that into a USB hub, and that is plugged into the VIM3 SBC.
