I am after a recommendation of a wireless (Bluetooth) external GPS sensor that will be as quick as possible ( minimized lag ). I am asking for a recommendation since I don’t want to spend money and track time on trying different devices to end up using only one.
Please mind that I am connecting to the ECU via WiFi and I am using the port on the tablet for charging, so Bluetooth seems the best option here.
Hi, can you please confirm how you configured this in the Android app?
I have the same module, however i can only get it working via a helper app setting mock location at the moment, direct connection in RD is not working for me.
It does, specifically as i understand it the 10Hz mode requires the USB connection.
Using the “GPS connector” app on play store i can establish a wired connection to the Qstarz, this is the G Mouse function. In the app i select Generic USB GPS and the baud rate seems to work on 4800. I get GPS data, there is no BT pairing in this case.
However it’s not that reliable with the helper app etc, would be nicer connecting direct to RD.
Probably not as it seems to require their own driver. The 10hz mode works just fine over the Bluetooth.
Edit. Did some tests, and while RD can make a USB connection to this device, it does not seem to send anything and connection times out. It will propably work on Windows though if their custom driver is installed.
That’s a shame, it does receive data over USB via the GPS Connector app, so whatever that is doing to initiate the data stream you could do in RD, but i understand it’s not a priority.
