Hello, I tested in F1 2020, it looks OK, I had to put the IP of the phone in the game configuration. Ideally, the IP would appear in Realdash as it appears in Forza Horizon 4.
-Brake pedal position is showing with a value from 0 to 1.
Tks
Tks
Thank you for testing! I will multiply the brake pedal by 100. Throttle and clutch positions are ok? As ll those three are read the same way from data stream.
You’ll have to multiply those too, including:
-Steerring wheel angle.
Tks
Will do for the next release. Thank you for your help.
Please try 1.9.1-beta1 if you now get correct readings.
