when creating animations using an XML file using the “fade” animation type, animated sensors do not appear when the skin is reloaded.
But there is one point.
If there are two pages in the skin and you switch the pages back and forth, then the animation will work as needed again.Also, if the application does not start from the animation page, the user switches to it in the process, then everything works correctly.But if the application is loaded from the page where the “Fade” animation will be located, then the animated sensor will not appear.
When you save your dashboard, it also saves the current fade states of the gauges. You have to be careful to save your dashboard in its ‘default’ startup state.
Yes, I take that into account. I just want everyone to take this into account.
