Hello,
I have Windows 10 Version 10.0.19041 Build 19041 and RealDash v1.8.0.
When I try to “Load Custom Channel Description file” from the link below I get “Filed to parse channel description file”.
https://github.com/janimm/RealDash-extras/blob/master/RealDash-CAN/Arduino-examples/realdash_can_example.xml
Do you know what is the issue and how to fix it?
Regards,
Nikolay
The text file may be saved in a encoding that is not working. Double check that all the contents of XML is in your file and file is save as ANSI or UTF-8 text file.
It worked, thank you!
My problem was that I was adding the device as OBD2->Bluetooth instead of Analyzers->OBDLink->Bluetooth.
