Ford Fiesta MK8
i have found the data for my project and I will start assembling with LCD in a short time
CAN bus MM-CAN
500Kbps
(0x591, 0x91, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF); // Keep alive signal
(0x3B2, 0x45, 0x00, 0x00, 0x8E, B00000000, 0x00, B00000000, 0x00); //Ignition
(0x179, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00); //Odometer and Service
(0x156, 0x00, 0x00, 0x00, 0x00, 0x23, 0x00, 0x00, 0x00); //Coolant
(0x04C, 0x00, 85, 85, 0x00, 0x00, 0x00, 0x00, 0x00); //Airbag
(0x213, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00); //Parking Brake (Fusion 2013)
(0x3C3, 0x00, B11111111, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00); //Vehicle Alarm + Parking Brake
(0x416, 0x0E, 0x00, 0x00, 0x00, 0x00, B00000000, B00000000, 0x00); //absLight
(0x3b4, 0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00); //TPMS
(0x421, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00); //ECU
(0x42C, 0x00, 0x00, 0xA6, 0x00, 0x00, 0x00, 0x00, 0x00); //Charging System
(0x877, 0x23, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00); //Power Steering
(0x191, 65, 17, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00); //Language?
(0x3B3, 0x00, 0x00, 0x00, 0x00, 100, 0x00, 0xFF, 0x00); //Outside Temp
(0x3D8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00); //Front Camera
(0x46A, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00); //Tractioncontrol
(0x46B, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, B00000000); //High Beam + Auto Hed
(0x3b4, tpms, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00);
//Byte 1: 49=Shows Low Tire Pressure Menu, B00000100 shows still tire warning, B00001000 shows flashing tire warning
//Byte 2: Highlights Front R and L tires
//Byte 3: Same as above but rear
(0x416, 0x0E, 0x00, 0x00, 0x00, 0x00, tc, 0x00, 0x00);
//Byte 6: B00000100=Slow flashing TC, B00000010=Solid TC Light
//Byte 7: B10000000=Rapid flashing ABS, B01000000=Solid ABS
(0x3C3, 0x00, B11111111, handbrake, brakeApplied, 0x00, 0x00, 0x00, 0x00);
//Bytes 1/2: B11111111=Alarm
//Byte 3: B00010000=Park Brake
(0x3B2, B01000000, 0x00, 0x00, B1000000, blinkerR, 0x00, blinkerL, 0x00);
// Byte 4 B00000001 means dim, B0000100 means less dim, B0001000 means even less dim B0010000 means full brightness
// Last byte: B00000001 fog lights
// First byte: B01000010 fog light 2, B01000100 means day lights, B01000000 screen on, B10000000 screen off, B01000001 door ajar light
Nice information. How can i implent in a xml file? have you a file? thanks.
