Hi,
The current version forecloses from time to time, on 2 different Android devices (8 and 10), at least once a day, sometimes 2-3 times in 3 hours. It restarts immediately without a problem, but with the previous version was rock solid, it never restarted in months. No other changes to the system.
Thank you!
Ok, I will check the crash logs from Play store.
I can see some crashes related to OBD2 data parsing. You were using OBD2 connection, right?
Yes, OBDLINK LX plus CAN adapter. But only on one device, the other was just receiving data over multicast.
You are using it as CAN adapter instead of OBD2 connection?
no, separate adapter that I use since 2 years ago, the same that you mentioned as compatible on the website. I use OBDLink LX for some OBD2 commands that I can’t find via CAN (gear lever position and actual gear), the rest via CAN
