1- How to write the unsigned
parameter? I know the signed parameter is Signed=“true”.
2- Endianness=“big” i found it followed by signed=“true” in most of your xml files, is it a must?
3- i have a bit normally it is 1 and turn to 0 when press the button, is Realdash will consider it as change in the bit status and turn ON the indicator if it become 0? Please advise.
4- I found parameters Gear and Selector Gear in target ID, what is the purpose for each one?
5- i linked between my gearbox and Realdash Gear target ID and it reads fine after following your steps in one of your reply with another member, Now i noticed that text gauge is fluctating between N and D very fast, but when i open the CAN monitor the data are Fixed! Is there a timer can be used here or to add equation in Realdash as( X is bigger than Y but smaller than Z)?
6- what is the different between bit shift V>> and (bitstart and bitlength)?
Perhaps you have a conflict between your data and the logic of the application.
for example, you send “D”, but according to the logic of RealDash, it runs “N”, and there is a switch in fast mode from two sources.
Thanks for your support, regarding question #5, i solved the issue. The gear gauge was reading the value of the byte in two format ( value & text ) in the same time, for example if the value is 9 i made a trigger for text gauge to read N.
I solve it by edit>gear value(the required gauge)>Look N feel> Font & text>static text.
RealDash 1.7.7 has support to use ‘enum’ parameter in XML for easier display of text-per-value. See the announcement for 1.7.7 release for more info. We will update the GitHub examples too for this information.
