Fuel correction is not possible
! 20240813_173958|666x500
! 20240813_173949|666x500
Even if the fuel value is modified, it cannot be corrected.
If the method is wrong, please let me know.
The slider is quick settings adjust the ‘calculated’ fuel level. If your setup is configured to get the fuel level from a sensor, the quick settings slider does nothing.
Check where your fuel level data is coming from:
  • Open ‘Settings->Units & Values’ and go to ‘Input Mapping’ page
  • Use the search box for ‘fuel’ to inspect if fuel level is mapped to some input.
  • If there is no mapping for fuel level, you can add it:
    • Tap ‘ADD’ and select ‘Body Electronics->Fuel Level’ as target input
    • On next screen select ‘Calculated Values->Fuel Level (Calculated)’ as source input.
Now you see that new mapping appears saying ‘Fuel Level is set from Fuel Level (Calculated)’.
No addition is allowed.
I can’t upload the video to the forum here.
You were setting fuel level destination and source as same input.
  • Use the search bar to filter the input results
  • Select “Body Electronics->Fuel Level” as target.
  • Select “Calculated Values->Fuel Level (Calculated)” as source.
! 20240816_172245|666x500
I think this expresses the remaining distance.
How should I set this up?
If you subscribe, all premium themes.
Can I download it at will?
Fuel level problem solved
Can’t Korean be displayed when playing music??? Mark it like this.
! 20240818_214844|375x500
Another problem is.
I want to display the driving range. Please tell me how.
! 20240818_214828|690x387
I am using obd2.
! Screenshot_20240820_093412_RealDash|690x78
Please.
Please tell me how to display Korean properly.
This is because the font we have licensed for the dashboard does not include Korean special characters. Its something that we cannot fix currently, sorry :frowning:
The RealDash main font may work, so in some cases you could be able to make your own dashboard with default font. Not sure about this either I’m afraid.
[https://www.obdlink.com/products/obdlink-mxp/? ref=realdash](https://www.obdlink.com/products/obdlink-mxp/? ref=realdash)
I have a Kia Carnival (SEDONA) vehicle.
The obd2 I have now is on the realdash obd side.
Connect it.
Obdlink products will be connected through Can communication.
If you connect the can in realdash,
Can I see the turn signal and headlight?
Or do we need another operation?
Is it possible if I send you a free Korean font?
Yes, if you know the CAN addresses where this information is.
Just sending the font to us will not help, as we are unable to publish/sell our dashboards without permission from the font author. Fonts are typically free for non-commercial use.
But you can somewhat easily change the font on the dashboard by yourself:
  • Prepare your font file to some location where you can find it. TTF and OTF files are supported.
  • Open your dashboard and go to edit mode.
  • Select any text gauges you wish to show Korean text and go to ‘Look’n Feel->Font & Text’ and tap ‘Select Font’ button.
  • On asset selection popup, press the + sign to add new font asset.
  • Browse/import your own font file.
  • When back in select asset popup, tap upper left corner ‘Done’ until back in dashboard.
  • Exit Edit Mode and Save your dashboard
Thank you.
I modified everything else and applied it.
Distance to empty???
Even if you set it like this, you can’t calculate well.
It is said that the actual vehicle can go 100km.
It is marked as 23km.
Please tell me how.
I introduced it to the p.s Korean vehicle club.
Many of my friends expressed interest.
