Guys, on my journey with the real dash using an obd2 torque scanner, I was able to get the fuel level data using this device and to help those who are starting out, I will leave a channel where I have some information
good i w try in my dash
I tried but it didn’t work, it shows 0% fuel
Not all cars have this information in obd2 but it may also be a different configuration for your car.
In settings, go to units and values. On the second page, Input Mapping, set “Fuel Level IS SET FROM OBD2: Fuel Level”. The use Fuel Level for your gauge. If OBD2: Fuel Level is constantly 0 then the OBD2 isn’t reading the fuel level. I find the fuel level to be fairly accurate until about the last 2 gallons. It’ll never show me a true 0 even when I’ve ran out of gas. Also the value is a % so you can convert it in calculations if you know the fuel tank size of the vehicle.
