Has anyone implemented a g-meter showing acceleration forces from an IMU?
Not sure what you IMU is referring into, but RealDash is able to use devices internal acceleration sensor to display acceleration values. In addition there is a calculated forward acceleration based on change in speed.
The built-in acceleration sensor can give you a G-meter, but its axes depend on device mounting. You’ll need to calibrate orientation and subtract gravity to get useful lateral/longitudinal G. Speed-derived acceleration only covers forward/backward, so it won’t show cornering lateral G. If your IMU exposes raw accelerometer data, map the axes and apply a low-pass filter; if it’s a phone/tablet, use the internal sensor. The calculated forward acceleration is a reasonable fallback when no accelerometer is available.
