Hi,
If possible can a 2 rotor (1.3l) and 3 rotor 2.6l) rotary engine be included as an option in the engine list?
Will add these to next release. Though, will use the 3d model of electric motor for now.
Excellent thank you.
Can you explain what distance between services means?
Distance between services is used to give notification/warning about upcoming services. Set it to 5000 to get notification in every 5000 kilometres.
In other words, this is an inter-service interval, or as it is also called - the interval before maintenance!
