Hi,
I made a gauge for Air condition and it works fine in all premium dashs except Bavarian!
Please see link below.
https://drive.google.com/file/d/1EsqKJnaW8_2V0n6mj8aZfrlMVF2AGHin/view?usp=drivesdk
Regards
Hi,
Regards
I did some tests and was unable to re-produce this sort of the problem with Bavarian. I could not find anything in Bavarian that would set the AC active input.
I will try to change the gauge and see what will happen.
Also i found that if i select the Navigation in Bavarian you can not see turn left or right signals.
Can you please add them?
Regards
Lets see what we can do. It has been a bit hectic lately.
Hi Jani,
I found the issue, the AC gauge was linked to one of the trigger by mistake! Now it is working normally.
Note:
I test the turn signal again while Navigation but still not appear.
Thanks for your support
