Im using FLOOR(ID37/500) *5 to change the rpm to a 2 digit number.
It works until im done with edit mode and close out.
Is there something I am missing?
Tested this and could not find anything wrong. The image below seems like its been loaded on different device as gauges are not aligning properly. Are you sure you are loading your latest version on another device?
It’s the same device, just dual monitors. So, I’m working on it on a full size screen, and then testing on a 10.4” screen.
Gauge math just won’t hold after closing.
I change it by selecting none for the input, then reselect RPM and it goes back to 2 digits. I then save and upload to my dash. When I reopen it from either the .rp file or the edited version on my PC it goes back to 4 digits.
By chance, if you’re on PC, have you changed RealDash to show the app in the same screen ratio as the setup you want to use it on? It technically doesn’t have to be set to the exact same dimensions of your screen resolution, but at least the same screen ratio would make sure it fits.
This is for the alignment at least
That and do you have any possible animations with gauges changing position.
Yes, I know set the resolution to be the same.
I had an issue in an earlier post, but since found the way.
I do have some animations that change position, but i think its worked out.
I can’t figure out the gauge math from changing. I’m using the default text guage with a different font. Im assigning it RPM ID 37, but it wont keep. The formula stays, but each time the app closes it resets the text and ignores the gauge math.
Could you send me your dashboard file for analysis? Send to contact@realdash.net
