If you select gauges in a container and try to arrange them (Context menu > Arrange > Send Back/Bring to Front/Move Forwards/Send Backwards), nothing happens – the gauges stay in the order they were originally put into the container in. This happens on iOS; will test behavior on Windows later. I do not have an Android device at the moment for testing. Containers themselves as well as items not in a container work as intended.
As a workaround, do the following:
- Select the gauges you want to move in front of all other gauges in the container
- Context Menu > Arrange > Remove From Container
- The gauges are now in front of everything else on the dash page. If unselected, select them again, as well as the container you removed them from
- Context Menu > Arrange > Add To Container. This will place them in front of all other items in the container
