Currently using a Link G4+ Fury in combination with an HTG GCU transmission controller. While I’m getting my basic gears 1-8 to display I’m unable to find a way to display R, D, and Neutral. Link Registers these signals just fine and displays them accordingly on my laptop, Realdash simply displays 8 for Neutral and Reverse, while Drive (non-manual mode) displays the current gear. An added bonus would be a way to configure Realdash to display “M” for Manual mode.
Current the Output Values from the HTG to Link. While I can assume these are directly passed through to Realdash via Seedstudio adapter (CAN)
R=10
Neutral = 11
1= 1
2= 2
3= 3
4= 4
5= 5
6= 6
7= 7
8= 8
Not sure which end to start on but seeing as my Link registers the signal just fine I opt’d to start here.
Thanks!
While this does allow a numerical value to be displayed it only shows a numerical value and not the desired “position” such as P,N,D. Is it possible from the app side to edit this? Any attempt to update/change the xml file leads to a corrupted error on my end.
