If you export global triggers and then import them, they have distortions and stop working/ in RD 240 this problem not present
afeter import config file from garage ACTIONS change to the name Triggers
But i export
config_test.xml (40.7 KB)
But i export
upd
i check - problem start when export - RD 241 change name action
action name same as trigger name
Thank you for reporting. I found the issue and fixed. Will be in next release.
