Handling 8-bit Fuel Counter Rollover via RealDash CAN (Renault vehicle)
Hi RealDash Team,
​I am using an ESP32 as a CAN-to-USB bridge to display data from a Renault vehicle in RealDash using the RealDash CAN protocol.
​The vehicle provides an 8-bit rolling counter (0-255) for fuel consumption. Each increment represents exactly 80mm³ of fuel. Because it is only 8 bits, the value rolls over from 255 back to 0 very frequently (every 20.48 ml of fuel consumed).
​My questions regarding the best implementation are:
  1. ​If I map this 8-bit value to TargetID 258 (Fuel Consumed), does RealDash internally detect the rollover (255 → 0) and continue to accumulate the total volume? Or will the “Total Fuel Consumed” value reset or glitch when the byte wraps around?
  2. ​Given that I have a fixed increment of 80mm³ per pulse, would you recommend:
  • ​A) Sending the raw 8-bit counter and letting RealDash handle it (if rollover detection exists).
  • ​B) Linearizing the value in the ESP32 (sending a continuous 32-bit float/int representing total Liters) and mapping that to ID 258.
  • ​C) Using TargetID 490 (Fuel Flow)? (Though my data is a volume counter, not a flow rate).
  1. ​For long-term stats (average consumption, trip fuel), does RealDash persistence for ID 258 work better if the “Total Consumed” value is an ever-increasing number provided by the hardware?
​Setup Details:
  • ​Connection: USB (Serial) @ 921600bps.
  • ​Protocol: RealDash CAN.
​Thank you for your time and for such a great tool!
  1. No, the rollover is not detected and Total Fuel Consumed would just reset when value rolls over 255.
  2. Option B is the best for total fuel consumed, Option C is what we use to give instant Fuel Flow to RealDash to handle all the rest of the calculations.
  3. I believe best option is to send instant fuel flow to RealDash and let RD handle the rest.
Good afternoon.
I’m setting up RealDash for a Renault Megane 2 Phase 2.
Have you achieved the correct fuel consumption calculation?
Currently, no development has been done on the rollover values. We do have this on the radar though.
