Help folder android
Good afternoon, this problem of no longer recognizing files in the control units is due to changing the napcon folder from the Android root to the documents folder. After that, these problems started. When downloading the Realdash app, the napcon folder would appear in the Android root, and inside it the Realdash folder with its respective folders, decfile, and others. After this change to the Documents folder, these problems started happening.
I am having trouble accessing files on Android 16 with version 2.6.7; I installed version 2.6.2, and everything works fine on the same Android 16 device. Another issue involves the file storage in version 2.6.7: clients cannot access the files.
Use Amaze File Manager
