Hello everyone,
Im working on a real dash project. however its a toyota corolla with 4efe engine with NO CAN BUS communication . my attempt is to digital read the ecu generated RPM signal and then to feed the data to read dash via serial com. I scoped the ecu RPM signal and figured out it had duty of 50% and has a frequency around 28 at idle . with some basic coding i was able to get the rpm respnsive to throtle . how ever the RPM needle fluctuctaes all times even at idle and sometimes get frozen and also sometimes it lagy . i will attach my code and the ecu scoped rpm signal at idle. appriciate your help and support
// input pin can be any digital input
unsigned long inputPin = 3;
boolean inputState = false;
boolean lastInputState = false;
unsigned long count = 0L;
unsigned long rpm = 0;
unsigned long previousCountMillis = millis();
const long countMillis = 500L;
void setInputState() {
inputState = digitalRead(inputPin);
void setup() {
pinMode(inputPin, INPUT);
Serial.begin(115200);
void loop() {
SendCANFramesToSerial();
rpm = count*60;
// runs every time thru the loop
setInputState();
// count every transision HIGH<->LOW
if (inputState != lastInputState) {
count++;
lastInputState = inputState;
// ------- every half second, count is equal to Hz.---------------
if (millis() - previousCountMillis >= countMillis) {
previousCountMillis += countMillis;
// show Hz on Serial too if available
// Serial.print(count);
// Serial.println(" Hz");
// reset to zero for the next half second's sample
count = 0L;
// Serial.print(rpm);
// Serial.println(" RPM");
void SendCANFramesToSerial()
byte buf[8];
// build 1st CAN frame, RPM, MAP, CLT, TPS (just example data)
memcpy(buf, &rpm, 2);
SendCANFrameToSerial(3200, buf);
Serial.write(serialBlockTag, 4);
// CAN frame payload
Serial.write(frameData, 8);
Iam not reving . it just fluctuates
