Hello there. First of all, I apologize for my bad English.
Realdash program has been very good. I bought an indicator. But I can’t make changes to realdash exampe xml file as I want. I am writing this code but the signals are not working.
code:
I want to connect digital 4 and 5 pins. can you send code sample and arduino code for it? I downloaded the arduino example from github but the signals are not written. It would be great if you send an example in this regard.
Try this:
Sorry, it didn’t work. I could not introduce a pin in the Arduino. I am novice in arduino. I wrote realdas can example Do you have an example of introducing pin number to arduino?
The Arduino analog/digital pin numbers are dependent of your hardware and wiring. Its not possible to give a generic programming example of those.
problem solved. thank you your help.
Would you like to share your resolution
