I’m using GPS latitude and longitude that are on the CANbus. I have it working but when I originally loaded it, the location was way off. After getting the decimal point in the correct location, my longitude was still off, but I believe it’s wrong it’s because it’s a negative number. Using a hex to decimal calculator, the correct value was “signed 2’s compliment”. How can I represent that in the XML conversion? Here is my current xml, with a simple subtraction to dial in the location temporarily:
One more conversion I need help understanding. I have a coolant pressure sensor I’m sending from my link ecu:
The value I’m reading in the CAN monitor is AB, which is 171 which is the correct number in kPa of the current coolant pressure (25 psi). If i have no conversion, the number in RealDash is 43520. Most of my other numbers seem to read the CAN numbers directly. To correct this, I’m multiplying by “0.000571” to have realdash readout PSI.
