High Class Steampunk Premium Dashboard
High Class Steampunk Preview on YouTube
Step into a world of polished brass and analog precision with the High Class Steampunk dashboard! Vintage-inspired gauges take center stage, with glowing copper rings and elegant needles that sweep across rich, warm dials like instruments from a bygone era of grand touring. Every glance feels like you’re piloting a luxurious machine crafted by master engineers.
Tap the left gauge to swap between the classic RPM dial and a large map view perfect for cruising city streets in style. You can also use the toggles in the corners to cycle through different layouts.
Side dials reveal an arsenal of classic instrumentation, including coolant temperature, boost pressure, battery voltage, and fuel level — all beautifully rendered with old-world charm and modern clarity.
This dashboard is available for My RealDash subscribers. For more info, see
realdash.net
MyDashboard isn’t opening from Multimedia; the screen appears but doesn’t load.
